Activity Forums Apple Final Cut Pro Legacy Importing DVD footage into Final Cut Pro
  • Importing DVD footage into Final Cut Pro
    Posted by Jon Davidson on April 10, 2005 at 10:28 pm
    I want to import footage from a 10 minute DVD into Final Cut Pro to edit. It’s not copyright protected, just a friend’s demo reel. I have been able to copy the disk to my hard drive and watch it with DVD Player, but Final Cut Pro won’t recognize it, even though it is in MPEG-2 format. I have been able to import tutorial footage into FCP before from DVD with no
    problem. What’s going on? When I click on the disk, I get Video TS files. I try to import those with no success by dragging. Thanks for any insights.
    Shane Ross replied 21 years, 2 months ago 3 Members · 3 Replies
  • Shane Ross
    April 10, 2005 at 10:38 pm
    DVDxDV. Costs $25 and can be found at http://www.lafcpug.org in the store.
    I use this all the time.
  • Douglas Frey
    June 13, 2005 at 3:34 pm
    Is there any other way to import from DVD or is a third-party software the only way?
    Douglas
  • Shane Ross
    June 13, 2005 at 6:39 pm
    You can route the DVD player thru your camera and either record it to a DV tape (if it is a commercial copy protected DVD the camera won’t allow you to do this) or if the camera supports play-through you can capture the signal directly into FCP.
