Activity Forums Apple Final Cut Pro Legacy importing DVD
  • Posted by Marianne Souliez on January 24, 2011 at 2:18 pm
    Hello,
    I have browsed the forum to find a solution to import a movie from a DVD and have tried both MPEG Streamclip and Cinematize but in both cases, the end result is dreadful, even while preserving the 720×576.
    I need to retrieve the film in its original quality or as close as can be. Any help welcome.
    thank you very much!
    Jim Curtis replied 15 years, 8 months ago 4 Members · 3 Replies
  • Hector Berrebi
    January 24, 2011 at 2:31 pm
    Hi Marianne
    what settings did you use on mpeg streamclip?
    and to what did you transcode?
    was the DVD encoded straight from the original materials? or were there more encodings along the way?
    what was the original material shot on?
    most likely you will not be able to recover the original quality or even get close (depending on how demanding you’ll be) DVD’s are very compressed
    you could try capturing from a DVD deck with component out to a FCP system with proper capture card, and set the capture to prores SD
    some cards (AjA) are famous for decent looking uprezing from SD to HD, probably better than you could get by software
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Jerry Hofmann
    January 24, 2011 at 2:33 pm
    Most all of us are using MPEG Streamclip for the transfers… and it does a pretty good job of it all depending on how good the DVD was in the first place… it’s a garbage in, garbage out situation here. It can’t get better than what the DVD contained in the first place, but it should preserve most of that quality. Try choosing ProRes as the codec for the transcoded files for sure.
    Describe “Dreadful”…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jim Curtis
    January 24, 2011 at 5:55 pm
    [Marianne Souliez] “even while preserving the 720×576”
    So, this is PAL? If not, use 720 x 480 in MPEG Streamclip. To preserve quality, export as Animation 100% or ProRes HQ. Enable Lower Field first, and leave the other settings alone.
    You didn’t say, but if this is a DVD with Macrovision, that could account for the “dreadful” results.
    Jim Curtis
    jamesphilipcurtis.com
    MacPro (Harpertown-Early 2008) 2×4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.0.1); Primary display: 30″ ACD; Secondary: HP LP2480zx DreamColor (A) via AJA HDP2 SDI to HDMI converter and (B) DVI from MacPro.
