Activity Forums Adobe After Effects Importing DV into aftereffects 6
  • Importing DV into aftereffects 6
    Posted by Yumiko42 on March 2, 2006 at 2:11 am
    I am using aftereffects 6 and do not own premiere, which seems like the preferred way to import dv files (as opposed to quicktime files) into aftereffects. I know there is a plug-in that allows for direct import; short of that, is there any other way?
    Steve Roberts replied 20 years, 6 months ago 4 Members · 3 Replies
  • Aanarav Sareen
    March 2, 2006 at 5:44 am
    You should be able to import AVI files into AE without any problems. No need for a special program.
  • Josh Miller
    March 2, 2006 at 6:03 am
    There shouldn’t be a big problem when importing, you just have to make sure that your file is interpreted correctly by AE with lower field first and the right pixel aspect ratio
    Josh
    JoshM@goowy.com
  • Steve Roberts
    March 2, 2006 at 12:49 pm
    You can import digital files from disk into AE, but not from tape.
    For that you need a non-linear editor such as Premiere, or a utility such as Windows Movie Maker, if I recall correctly. (or iMovie on Mac)
