Activity Forums Apple Final Cut Pro Legacy Importing DV footage into FCP 5
  • Importing DV footage into FCP 5
    Posted by Brids78 on April 24, 2006 at 2:19 pm
    Hi
    I have importing problems from DV tapes into FCP 5.
    I got those tapes from a client and when I import them the material looks blocky…(https://www.geocities.com/brids78/Bild_1.jpg)
    Other tapes work fine. The problems are tape-related.
    Can anyone think of a solution, maybe in the videosettings, a different project setup, anything?
    Thanks FLO
    Matt Gorney replied 20 years ago 3 Members · 2 Replies
  • scottwitt Scott witt
    April 24, 2006 at 3:18 pm
    I would TRY fast forwarding all the way to the end of the tape and then rewinding to the beginning.
    I am guessing the tape may have been loose when recorded and there may not be a fix.
    Sorry.
    This is by no means a fix, it is a try and see.
    scott
  • Matt Gorney
    April 24, 2006 at 6:01 pm
    Could be the tape…do you know what camera they used?
    Is The tape SECAM, NTSC, PAL?
    It doesn’t look like a format issue, but you never know.
    Are you working in the same format?
    Sometimes when you apply new settings to FCP Projects you must close and restart
    the application to get it to work right.
    -Matt
