Activity Forums Square Box CatDV Importing DPX Sequences into CatDV
  • Importing DPX Sequences into CatDV
    Posted by Eli Garrett on April 25, 2016 at 4:32 pm
    I have about 50 DPX sequences that I want CatDV to track. I can import a image sequence to get Catdv to track the DPX sequence., but I can only do it one by one and it takes a really long time for it to import. Is there any way to bulk import DPX sequences in Catdv? After I have gotten 2 or 3 sequences into Catdv it becomes really slow and almost unusable any recommendations for how to handle DPX in Catdv?
    Dougal Matthews replied 10 years, 4 months ago 2 Members · 1 Reply
  • Dougal Matthews
    April 26, 2016 at 12:54 pm
    hi Eli
    as you have discovered the client isn’t really built for bulk import we have a companion tool called the worker which is designed for that sort of automation see
    https://www.squarebox.com/worker-node-6/
    so if you regularly need bulk import I’d suggest using the Worker
    thank you Dougal
    Improvise Adapt and Overcome
