Activity › Forums › Adobe Premiere Pro › importing deleted footage back to project hard drive
  • importing deleted footage back to project hard drive
    Posted by Yossi Forkush on March 27, 2011 at 6:51 am
    accidently deleted my footage from my hard drive, how to i get it back from my backup hard drive so it will sit where it was before deleted, using Premiere Pro CS5
    Yossi Forkush replied 15 years, 6 months ago 2 Members · 2 Replies
  • David Esteban
    March 27, 2011 at 5:30 pm
    Simply select the missing footage on your project window, right click over it and then select “Replace footage”. A window will pop up, where you can browse and find your original file. Although i recommend to first make a copy of your original file in case you accidently delete it again.
    If you can’t find your footage on you project window, you can right click over the desired clip on your timeline, and select “Reveal in project”
  • Yossi Forkush
    March 27, 2011 at 8:46 pm
    Hi David
    problem is, the backup footage is on a removable hard disk and i want it to get copied into the internal hard drive where it originally was, not just to reffer to a new clip.
