Activity Forums Maxon Cinema 4D Importing color
  • Importing color
    Posted by Thew on September 19, 2005 at 2:22 pm
    Trying to import an Illustrator file into 4d, however, I cannot figure out how to get my seperate colors from Illustrator into my 4d doc, any ideas..
    THanks
    Chris Smith replied 21 years ago 2 Members · 1 Reply
  • Chris Smith
    September 20, 2005 at 2:02 pm
    If you are importing your Illustrator curves directly into C4D, there will be no colors because C4D wouldn’t have a way to show or render them. Splines in C4D don’t render much less have a renderable color.
    You can use your splines to drop into sweeps, lofts, and extrudes to create geometry that does render. Then on that geometry you can match the colors from your original ai file.
    Chris Smith
    https://www.sugarfilmproduction.com
