Activity Forums Adobe Premiere Pro Importing Clips, transcoded from FCP
  • Importing Clips, transcoded from FCP
    Posted by Todd Schmidt on January 6, 2015 at 6:03 pm
    Hi all,
    I’m working in:
    Win 8.1
    Adobe CC 2014 V8.1
    I was given a project that obviously isn’t working.My colleague that sent it has sort of left me in the dark as he isn’t much of an editor. He actually didn’t edit the original either.
    When I try to link the media, I get the dreadful Codec not supported or missing. The clips are in a .mov container and will only open in MPC. I did some research on the codec, xd54 and it comes up as a pro-res codec…I could be wrong, but I’m thinking these were first trans coded in FCP (grrr, then the project was somehow reassembled in PP on a Mac. Does this make sense or am I out of my league?
    Anyways, I spoke with the director and he said it was a tricaster shoot and he thinks it might’ve been done in Avid. But he doesn’t really know (grrrr).
    Any hoot, I save the clips properties. they are posted below. Any expert help would be appreciated.
    Todd
    Properties:
    General
    Complete name : F:\EASTER PLAY RESHOOT\PROGRAM RAW\720 24P TEMPLATE 54 (Camera 1).mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 229 MiB
    Duration : 53s 328ms
    Overall bit rate mode : Variable
    Overall bit rate : 36.0 Mbps
    Encoded date : UTC 2014-05-23 04:42:08
    Tagged date : UTC 2014-06-24 03:00:27
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : High@High 1440
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Codec ID : xd54
    Duration : 53s 95ms
    Bit rate mode : Variable
    Bit rate : 34.6 Mbps
    Maximum bit rate : 61.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.564
    Time code of first frame : 21:41:14:23
    Time code source : Group of pictures header
    Stream size : 219 MiB (96%)
    Language : English
    Tagged date : UTC 2014-05-23 04:42:08
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel count : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 9.76 MiB (4%)
    Language : English
    Todd Schmidt replied 11 years, 8 months ago 4 Members · 16 Replies
  • 16 Replies
  • John Pale
    January 6, 2015 at 6:14 pm
    I thinks that’s the XDCAM implementation from either Avid or FCP.
    Download the trial of this product and see if it helps.
    https://www.calibratedsoftware.com/Products/XDDecodeV2/QXD.php
  • Todd Schmidt
    January 7, 2015 at 2:19 am
    Thanks John,
    You were right on the money. $149 per license. I’m wondering if there is any other options out there though? A tad bit cheaper haha!
    Todd
  • Tim Kolb
    January 7, 2015 at 10:33 pm
    Unfortunately Apple decided to make a few FCP rewraps proprietary to their pro apps and not include them in standard QuickTime.
    I don’t know of a way to use this post-FCP material on Windows outside of getting the Calibrated software product or similar.
    TimK,
    Director, Consultant
    Video Producer at I-CAR
  • Todd Schmidt
    January 7, 2015 at 11:28 pm
    The guy who shot this exported from a tricaster. He says that it works perfectly fine on his system in FCP, Premiere and Avid. But he’s on a Mac and I’m on Windows.
    When I installed the trial of Calibrated (Q) XD Decode, it works with the of course the watermark. ALso, he says it’s pro res 4:2:2. Which it clearly shows the xd54. Not sure if that’s the same thing.
    If I buy QT pro, do you think that might do the trick and install certain codecs I don’t get with my version of QT?
    Todd
  • Tim Kolb
    January 7, 2015 at 11:58 pm
    No. QuickTime Pro doesn’t have the codec.
    The reason why everything on his Mac recognized the media was because FCP was installed on it and the codec was available to all the applications on his system.
    Even a Mac wouldn’t be able to run this material without FCP or Motion installed.
    TimK,
  • Todd Schmidt
    January 8, 2015 at 2:44 am
    Thanks Tim,
    I’ve called Adobe and they told me that the xd54 codec is available through QT for Windows, but for the life of me I can’t find it. They said it’s a prores codec. I’ve Googled my butt off trying to find it, not finding anything but the $149 decoder. I was told that the tricastor is Windows based and that I should have no problem, which I don’t believe.
    I’m running out of options.
    Todd
  • Todd Schmidt
    January 8, 2015 at 2:52 am
    Ok…weird. I think I figured this out. Well…I did but it’s odd. I changed the extension to an mpg and it works. It was originally a QT. So now I have to change a million clips to mpg and I’m golden. ODD!
    Todd
  • Tim Kolb
    January 8, 2015 at 3:00 am
    Now that I look at the specs you have, it looks like ProRes…no long GOP encoding.
    If that is the case, you should be able to decode it with a current installation of QT for Windows. I handle (playback, not encode) ProRes on my Windows systems frequently enough.
    TimK,
  • Tim Kolb
    January 8, 2015 at 3:02 am
    [Todd Schmidt] “Ok…weird. I think I figured this out. Well…I did but it’s odd. I changed the extension to an mpg and it works. It was originally a QT. So now I have to change a million clips to mpg and I’m golden. ODD!”
    Really? Wow…that IS wacky. An MPG extension shouldn’t allow playback of a ProRes file…
    TimK,
  • Todd Schmidt
    January 8, 2015 at 4:28 am
    Hi Tim,
    I have the latest QT for Windows 7.7.6 and have Pro which is up to date. I’m able to only get audio, no video after I installed the trial version of Sheervideo Pro. I’ve installed AvidCodecsLE234 and 2.3.8
    When I open QT player and choose “open”, I’m getting a thumbnail.
    The only things that works is changing them to an mpg.
    Grrr!
