Activity Forums Apple Final Cut Pro Legacy importing clips to fcp
  • importing clips to fcp
    Posted by Alex Sorkin on April 24, 2011 at 1:45 pm
    hi, I need your help i have a canon legria hf200, and i took all my clips from from the folder on the SD card and by doing that basically ruining the original structure of the card.
    i’ve re-wraped with clipwrap
    ,and when I import them to fcp they play choppy and i cant share or export the sequence, fcp crushes. in output format the only other formats that are available except re-wraping, are dv and aic,
    ProRes or ProRes LT are not available.
    In both formats the playback is excellent, but when I try to add video transitions I get the error massage “there was insufficient media for the requested transion at one or more edit points.” the duration of both clips is about 2 minutes/ plz help
    Ron Pestes replied 15 years, 5 months ago 2 Members · 1 Reply
  • Ron Pestes
    April 24, 2011 at 8:49 pm
    It sounds like one of more of your edit points is at the end of the original media. You need to set your in and out points with at least a half second handle for the default transition to work.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
