Activity › Forums › Media 100 › Importing Clips from AE
  • Importing Clips from AE
    Posted by Mark Honer on May 6, 2005 at 11:29 pm
    I’ve created some clips in After Effects and am having a very annoying problem getting the clips to import correctly back into Media 100. The clips I’ve created look great when viewed in Quicktime. But when I import into M100, I’m getting some tearing video in the spots where there is a little motion on the screen. Whenever there’s some movement, the video looks a little jittery or it tears.
    I’ve tried using both the M100 and Animation codec in creating the file in AE…but both look the same when I import back into M100 to assemble the clips into a program. I’ve been using m100 for eight years and never seen this before. Running OS X with v 8.2.2.
    Any help would be appreciated.
    Ernie Geefay replied 20 years ago 3 Members · 3 Replies
  • Tim Scarpino
    May 9, 2005 at 8:05 pm
    This might be a long-shot, but have you activated the anti-aliasing function on your effect? I don’t have AE open right now, but on the timeline, for each layer, there’s a slash that if it looks jagged, means the anti-aliasing is off. Click on the slash until it appears smooth, then make your movie and import into Media 100. Maybe this will help, though it will slow AE down a bit.
    Good Luck,
    Tim
  • Ernie Geefay
    September 25, 2006 at 10:29 pm
    I have been having the same problem.
    It always happens on movies rendered in After Effects
    Did you find a fix?
  • Ernie Geefay
    Did you find a fix?
