Importing clips from a media folder. Cant See subfolders.
I need to import clips from a clients HD that i am using for this job. i cant change the file structure of anything , only add to it.
There is one folder loaded with all the clips and media i need, It also has alot of media i dont need.
My problem is this. The folder i need to look into has all sub folders with everything organized. When i look into that folder in fcpx import no sub folders are found, just all the files from the subfolders. like 3000 files. How can i view the sub folders?
in FCPx 10.0.7
i go to Import/Media. When i look at the folders on this external, to the right of the folders there is a file type tab and all the folders are marked “Folder” and the folder i need to get into to import some of the sub folders contents is marked “Media Folder” under the file type tab.
That is the only explanation i can see, is there a way around that so I can see all the sub folders?
Here i can see the folder i need to get into.
When i open that folder i get hit with 3,262 items without the sub folders. To the right is what the file system looks like on the external.
