Activity Forums Square Box CatDV Importing CatDV database issues
  • Importing CatDV database issues
    Posted by Jason Perr on May 17, 2012 at 5:54 pm
    I’m having trouble getting a CatDV database imported. Using CatDV Server 6.6b13. Whenever I restore the db the server installation status is green, the database is green, but the CatDV Server is never finishing and the logs keep saying that tables dont exist (which I verify they actually do exist). The whole installation works fine if I reinstall but the second I try to restore from my database sql backup these errors start happening.
    Strangest thing is that I get these errors like:
    [1;10:46:49.689] err=java.sql.SQLException: Table ‘catdv.clipTypes’ doesn’t exist
    When that database table does exist and the permissions are wide open in MySQL.
    Also getting this one:
    Error: loadClipTypes “Table ‘catdv.clipTypes’ doesn’t exist” (id=-1, numClips=-1) serveradmin@console @ mainserver.media.lan
    Which really is strange. It seems like CatDV is trying to access the database through a user called serveradmin@console@mainserver.media.lan
    my database url is set to:
    jdbc:mysql://localhost/catdv?user=catdv&password=catdv
    host:172.16.1.201
    port: 1099
    Anyone seen this before? Any ideas?
    – Jason
    Rolf Howarth replied 14 years, 2 months ago 4 Members · 6 Replies
  • Rolf Howarth
    May 17, 2012 at 8:34 pm
    I don’t recognise those errors I’m afraid. What exactly are you trying to import? A backupXXX.sql file from another machine, or an older backup on that machine? And what are you using, the Import Database.. command from the Control Panel? Is the backup fairly recent or is from a much old system?
  • Robb Harriss
    May 17, 2012 at 11:44 pm
    That’s an odd ip address for an internal intranet. Are you trying to connect to a server over the web?
    Non-linear: all the time and nothing but.
  • Jason Perr
    May 18, 2012 at 1:20 am
    its a backupXXX.sql file from another machine.Backup is from CatDV 6.5b26 for the server and the user app is 8.1.11.
    – Jason
    Jason Perr
    Solutions Architect
    Levels Beyond
    jperr@levelsbeyond.com
  • Jason Perr
    May 18, 2012 at 4:44 pm
    no just internal
    Jason Perr
    Solutions Architect
    Levels Beyond
  • Bryson Jones
    June 15, 2012 at 2:14 am
    Spoke to Jason and this appears to be a mis-match of versions of server. I’m assuming that the schemas weren’t updated and so it wouldn’t import.
    Rolf, or other support crew, can you confirm that this is the case? Can a Windows db be restored onto a Mac and vice versa as long as versions match?
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Rolf Howarth
    June 15, 2012 at 10:24 pm
    You should be able to restore them across different platforms, yes, though I must admit this isn’t something that’s extensively tested. I’m sure we can provide help to get it to work if necessary.
