Activity › Forums › Avid Media Composer › Importing Canon 7D footage at 60fps to achieve slow mo effect
  • Importing Canon 7D footage at 60fps to achieve slow mo effect
    Posted by Thomas Ramsey on December 16, 2010 at 9:39 pm
    Hi everyone,
    I am having a problem with some 7D footage I shot. It was shot at 60fps and the native clip looks sped up. What I am trying to achieve when in Avid is take the 60fps footage and make it a nice smooth slow motion video.
    Any advice on import settings, etc. that could help?
    T.
    Bill Ravens replied 15 years, 9 months ago 3 Members · 2 Replies
  • Job Ter burg
    December 16, 2010 at 10:38 pm
    Are you using AMA or regular imports? If the latter is the case, you may need to read up on the console command “IgnoreQTRate True”. It will import frame-by-frame, as long as the audio is stripped from the clip.
  • Bill Ravens
    December 18, 2010 at 1:22 am
    hmmmm…I don’t know of any cams that record at 60 fps progressive. So, assuming you recorded at 60fps Interlaced, what frame rate are you using to import into AMC?
