Activity Forums Maxon Cinema 4D Importing C4D into After Effects with transparency
  • Importing C4D into After Effects with transparency
    Posted by Jon Simpson on November 2, 2013 at 8:39 pm
    I have hunted around and not found a working answer for this, but I have a project I am trying to import into AE without a bg – only the objects in animation. I tried creating an .aec file with .png instead of .tiff and that did not work. Seems like this should be a simple thing…
    Adam Trachtenberg replied 12 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 3, 2013 at 3:44 am
    You need to check the “save alpha” box in the Render>Save settings. As long as there’s no background or sky object in your scene and you save to a compatible format (like .png or .tif) then AE should interpret the alpha channel.
