Activity Forums Adobe After Effects Importing Bryce 3D objects into After effects
  • Importing Bryce 3D objects into After effects
    Posted by Melissa Kern on February 18, 2006 at 11:24 am
    I want to import the 3D objects that I am making in Bryce 5 into After Effects 6.5…so, far it hasn’t worked.I am new to Bryce and don’t completely understand the procedure…do you have any experience with the program? I know that After Effects will support Maya, 3D studio, and a bunch of others formats…I need to know if there is anyway to get Bryce objects into After Effects-because if there isn’t I will try out a different program before I get too deep into Bryce.
    thanks-appreciate any help on this. really
    mak
    Andrew Yoole replied 20 years, 7 months ago 2 Members · 1 Reply
  • Andrew Yoole
    February 19, 2006 at 1:42 pm
    AE won’t import ANY 3D object natively, regardless of what application it came from. A third-party plugin will allow you to work with true 3D objects within an AE layer: Zaxwerks 3D Invigorator
    https://www.zaxwerks.com
    Save your Bryce object as a standard 3D file (like 3DMF) then import to 3D Inv. within AE. You will need to re-texture it etc.
