Activity Forums Adobe Encore DVD Importing Blu-ray m2v File from Compressor Into Encore
  • Importing Blu-ray m2v File from Compressor Into Encore
    Posted by John-paul Palescandolo on October 13, 2011 at 12:20 pm
    I’m just beginning to experiment with Encore and Blu-ray and just wanted to ask a few quick questions about my first import into Encore.
    I encoded an m2v file, made in Apple Compressor 3.5.3, and imported both that and its accompanying ac3 file into Encore. Here’s what the item info next to each file says . Next to the ac3 file, everything says “Don’t Transcode.” Next to the m2v file, DVD Transcode Status says Untranscoded, DVD Transcode Settings are Automatic, Blu-ray Transcode Status and Settings both say Don’t Transcode.
    I just want to be sure that this is all correct. Also, in terms of setting nitrates for the Blu-ray encode, how is an Average Bitrate of 32.3 and a Mbps and a Maximum Bitrate of 38 Mbps? The version of Encore that I have is 5.0.0.508
    Daniel Ludwig replied 14 years, 11 months ago 3 Members · 2 Replies
  • Chris Tompkins
    October 16, 2011 at 1:11 pm
    Your good, all set, no worries.
    Chris Tompkins
    Video Atlanta LLC
  • Daniel Ludwig
    October 19, 2011 at 8:15 pm
    as chris replied – all is looking good so far, but I would advice to use H264, as you can use lower bitrates at the same picture-quality, so you have more space for content on your BD.
    if you need to have 35-38MBits with MPEG2 you can use 18-20MBit with H264 for example.
    cheers
    danny
