Activity › Forums › Adobe Premiere Pro › Importing bigger framesized Media (960×540) into a Widescreen DV Projekt (720×576)
  • Importing bigger framesized Media (960×540) into a Widescreen DV Projekt (720×576)
    Posted by Henning Stirner on August 13, 2011 at 1:35 pm
    I want to includ footage with 960×540 framesize into an regular Widescreen DV Project. Is there any possibility to scale the bigger frames down? At the moment, if I set the program monitor to “fit” there is a black frame around the picture, if I chose “100%” the picture appears “zoomed in”.
    Henning Stirner replied 15 years, 1 month ago 2 Members · 2 Replies
  • Steve Brame
    August 13, 2011 at 3:18 pm
    Yes there is! Just click on the ‘Effect Control’ tab, then click the ‘Motion’ twirl-down button under the ‘Video Effects’ heading, and from there you can ‘Scale’ the frame to your needs.
    Steve Brame
    creative illusions Productions
  • Henning Stirner
    August 16, 2011 at 10:59 am
    Thank you Steve! It all worked well the way you explained – Thanks again and best wishes from Berlin!
