Activity Forums Adobe After Effects Importing baked dynamic animation from C4D into Element 3D v2
  • Importing baked dynamic animation from C4D into Element 3D v2
    Posted by Justin Rogers on April 7, 2017 at 6:25 pm
    Hi all
    I’m having problems importing a C4D animation into After Effects Element 3Dv2. The objects area all converted to mesh, the animations are baked using standard bake (plus I’ve tried SteadyBake and KeyMate plugins) I’ve also set the Output range to All Frames.
    However, when I import the .c4d file into Element 3D v2 (ensuring to check the ‘Load Animation’ box) it only shows one frame. Could someone kindly help me out, going a bit nuts.
    Justin Rogers replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
