Activity › Forums › Avid Media Composer › Importing Avid 5 to Avid 8
  • Michael Phillips
    December 12, 2016 at 12:28 am
    It should just open, but a better process is to create a new project of the same format/frame rate. Quit Media Composer and copy the bins from the older project into the new project. Relaunch, open project and bins as you would usually do.
    Michael
  • Job Ter burg
    December 12, 2016 at 3:36 pm
    Should just open, and if you’re unsure, create a new project in v8 and copy the v5 bins into it. Do note that 8.6.x has a problem where it often refuses to open bins from earlier versions (error messages appear). 8.5.3 seems to open them fine for me.
  • Eric Merklein
    December 12, 2016 at 9:18 pm
    Thank you for the info Michael. I’ll be getting to it tomorrow.
    Best,
    Eric
    Many thanks.
