Activity Forums Apple Final Cut Pro Legacy importing .avi captures into fcp-hd
  • importing .avi captures into fcp-hd
    Posted by Steven Cohen on December 24, 2006 at 7:53 pm
    I have about 20 hours of dvcam and/or dv footage, both df and ndf, that was captured perfectly into Canopus Edius 2.5 as .avi files. The .avi files contain original camera timecode and have all been “re-named” in Edius. My volunteer fcp-only editor tells me that none of these files can be used in fcp-hd….but a still photographer I recently met told me that fcp-hd can easily use-import-read .avi files via a simple, inexpensive pkug-in. Any help would be appreciated, as this is a pro bono charity documentary project with a 30-day deadline. Thanks……
    David Bogie replied 19 years, 9 months ago 5 Members · 4 Replies
  • Steven Gonzales
    December 24, 2006 at 9:41 pm
    There’s something called isquint, which is billed as iPod video conversion, but apparently can do a lot more.
    https://www.versiontracker.com/dyn/moreinfo/macosx/28250
  • Jerry Hofmann
    December 24, 2006 at 10:18 pm
    I’ve edited AVI’s in FCP.. it usually works just fine. If they are DV they will very likely work.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Dananderiq
    December 25, 2006 at 10:20 pm
    I have all my files that were imported by Premier Pro 1.5 as AVI’s. When I import them into FCP 5, it warns me that I should re captrure the footage. But the footage plays fine and looks fine (in the canvas). Do I really need to re capture?
  • David Bogie
    December 26, 2006 at 4:07 pm
    AVI is just a wrapper. like Quicktime. it’s not a specific format or codec.
    You won’t know until something breaks.
    bogiesan
