Activity Forums Apple Final Cut Pro Legacy Importing AVCHD gets slower with longer clips?
  • Importing AVCHD gets slower with longer clips?
    Posted by Michael Peele on March 19, 2010 at 10:59 pm
    Aloha,
    Successfully Log and Transferring AVCHD clips to our storage drive as ProRes 422.
    Small issue that is a bit of a problem.
    As my clips get longer the import time gets longer and longer (well, duh, but hold on).
    For short clips (under 1-2min) the import time is 1/3 realtime.
    For medium clips (4-6 min) the import time is about realtime.
    For longer clips (8-10 min) the import time is DOUBLE realtime.
    Who knows what the time will be when I record something that is 40 min long!?!
    First I was trying the transfer off of the memory card. Then I tried transferring the clips to a hard drive first (7200rpm FW800) for their conversion to a separate hard drive. The machines are Dual 2.66GHz Quad-Core Xeons with 12GB of RAM. Running the latest FCP Studio on 10.5.8.
    Any ideas? Thanks for the help!
    Mike
    Brent Hilgenkamp replied 15 years, 11 months ago 2 Members · 2 Replies
  • Michael Peele
    March 25, 2010 at 9:48 pm
    Figured it out.
    The Sony NX5U has two audio recording modes – PCM and AC3.
    PCM (higher quality/less compression/larger file) takes about 3-4X realtime when the clip is over 5min – making the import about 20min – no good.
    Using AC3 I am able to convert 13.5min to ProRes422 in about 3.75min – awesome.
    So the long and short of it – use AC3 audio. At least in the meantime, especially for LONG clips, situations where audio quality is not absolutely paramount or for time sensitive editing.
    Cool.
  • Brent Hilgenkamp
    October 8, 2010 at 11:05 pm
    Question – if your end product will be a DVD using AC3 audio does recording AC3 matter? I have this same problem with my NXCAMs and if the audio quality in the end will be the same I would much rather use AC3 in the field.
