Activity Forums Creative Community Conversations Importing avchd files from a folder as file import, do not work.
  • Importing avchd files from a folder as file import, do not work.
    Posted by Svend Haerra on July 30, 2011 at 8:18 am
    Fcp x says that it can not import avchd files from an folder but only direcktly from the camera….? Any tips on how to import avchd from a folder, and the rigth setting for importing 😉
    Teresa Bush replied 15 years ago 4 Members · 3 Replies
  • Alban Egger
    July 30, 2011 at 10:28 am
    try “Import from Camera”, then select the folder. If you have the footage in its structure as it was in the camera, then that´s how you do it.
  • Paul Jay
    July 30, 2011 at 3:42 pm
    It’s a camera archive, so import from camera is needed.
    Select the AVCHD folder as root. done.
  • Teresa Bush
    August 7, 2011 at 9:55 am
    Actually, FCP X would read AVCHD folder on Mac hard drive with the original camera structure.
    Choose “Import from Camera”, right click on the pop-up window, and choose “Open Archive”. It should be like the below:
    Of course, you should choose AVCHD or BDMV as the folder to open. 😉
