Activity Forums Adobe After Effects importing assets
  • importing assets
    Posted by Chris Brett on November 23, 2016 at 10:33 am
    Hi
    – have 2 very large projects and I want to import some of the assets of one into the other
    – any suggestions please on best workflow
    ———————————— chris —
    Chris Brett replied 9 years, 10 months ago 2 Members · 4 Replies
  • Chris Brett
    November 23, 2016 at 10:46 am
    — sorry – should have been more precise ” importing some assets, some comps, and some of the setups…”
    ——————————–chris —
  • Chris Brett
    November 23, 2016 at 11:41 am
    ————— sorted !
  • Krishna Moorthy
    November 23, 2016 at 2:45 pm
    You must import one .aep file into other and then use whatever assets you need. Then, reduce the project with your main comp. Hope this the solution as far I understood your situation.
  • Chris Brett
    November 23, 2016 at 3:09 pm
    — thank you Krishna — will remember that
    — a bit more elegant than what I ended up with — many thanks —c—-
