Activity › Forums › Avid Media Composer › importing Apple ProRes HQ files into avid media composer
  • Justin Gray
    July 2, 2010 at 5:45 pm
    MC5 handles natively via AMA.
    – Justin Gray
  • Michael Hancock
    July 2, 2010 at 5:49 pm
    If you can watch the files in Quicktime, Avid will see them.
    The ProRes decoder is included with Quicktime 7 and higher, I believe. If you’re running an older version of Avid and can’t upgrade your Quicktime that high, download the decoder and see if it reads the files then. Here’s the Windows ProRes decoder – the Mac decoder should be on the Apple site as well (I had this one bookmarked).
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows
    Michael Hancock
    http://www.oswaldcommunications.com
  • David Bushey
    July 2, 2010 at 6:45 pm
    thanks to you both!
  • Justin Gray
    July 2, 2010 at 7:58 pm
    David, which version of MC are you using? If not MC5 Avid has a special upgrade price available for a couple more weeks. It’s well worth the investment especially with any file based workflow. Native support on Quicktime, XDCAM EX, R3D, and many more through AMA.
    – Justin Gray
