Activity Forums Apple Final Cut Pro Legacy importing an OMF into FCP
  • importing an OMF into FCP
    Posted by Ceri Allen on May 16, 2008 at 4:45 pm
    Hi
    Just wondering if it is possible to use an OMF file in final cut pro (I’m on version 6.0.2)?
    I have a sound mix that was created in pro tools that I want to put into final cut with all the channels separated rather than just as a wav. The OMF’s I have are coming up with ‘file not recognized’. My 2 questions rea:
    -Can OMF files actually be imported into final cut?
    -If not, is there any way of getting sound from pro tools into final cut and retaining all the different channels?
    Many thanks for any replies
    Ceri
    Hamid Shams replied 16 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 16, 2008 at 4:52 pm
    OMF files cannot be imported into FCP. Not sure if Automatic Duck (www.automaticduck.com) now supports this…but it might.
    What I do is have the mixer send me individual AIFF files for each track of audio. Slightly more work on his end, I know, but it works well. And it is free.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Aaron Neitz
    May 16, 2008 at 5:02 pm
    In a pinch you CAN import OMFs into Soundtrack. Then you can export splits out as aiff for final cut.
    …so if Soundtrack can do it, I would hope it’s a feature that FCP could handle someday.
  • Bob Roberts
    May 16, 2008 at 5:32 pm
    WOW!!! This is the first time I’ve ever opened Soundtrack. Thanks for the info 🙂
  • Iryna Tietje
    September 30, 2009 at 8:18 am
    Hi Aaron, have a question. i just try to import an omf file into sound track. but it does not function. can you tell me, how did you import your omfs into sound track? thanks a lot
  • Hamid Shams
    July 5, 2010 at 9:42 pm
    Does anyone know if there is any quality loss when you use Automatic Duck to transfer Avid files to FCP?
    Also, can you transfer your timeline into FCP as well?
    Many thanks
    H
  • Shane Ross
    July 5, 2010 at 11:01 pm
    Hamid. You can only send sequences from Avid to Fcp, and from FCP to Avid with Automatic duck. You can’t send all the media, unless you make a sequence with all the footage a long sequence (but I haven’t tested that). And there is a shift in the gamma, slightly brighter, but color correction will fix that.
    There really us no way to transfer a full project, bin structure and all the footage, from FCP to Avid or Avid to FCP.
    Shane
  • Hamid Shams
    July 6, 2010 at 11:31 am
    Thank you for your answer. I appreciate it.
