Activity › Forums › Apple Final Cut Pro Legacy › Importing an Image Sequence
  • Importing an Image Sequence
    Posted by Tarun Kumaria on May 4, 2005 at 1:34 pm
    I am new to FCP but have worked on other editing softwares. Ive found that the only way one can import and image sequence into FCP is by first converting the sequence to a movie using Quicktime Pro. If its one odd sequence then its fine but here we are dealing with appox 650 odd such image sequences with varying duration.
    Is it the only way? I did a search and found on post of 13th April ’05 saying the same question the answer was using Quicktime Pro. I strongly believe there has to be a way coz a software like Premier or Edit one can easily import an image sequence.
    Suggestions please…
    Tarun
    Kevin Monahan replied 21 years, 5 months ago 2 Members · 1 Reply
  • Kevin Monahan
    May 4, 2005 at 9:42 pm
    If you absolutely need a .mov, then QT Pro is it. Otherwise you can import them as a bin, then drop the bin onto the timeline. Or you can make a new sequence and nest them to treat them as a clip. No way to stitch them as a QuickTime w/o exporting-importing them as QT.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
