Importing an Illustrator file into After Effects and animating it
I have a drawing in my Illustrator file (A perfect rounded circle and the same objects with the same size around it). I successfully exported and imported it into After Effects. The problem is that when I want to rotate vector image file, I see it drifts (not a perfect rotation). I exported the file as 1024px * 1024px and vector shapes were perfectly aligned with each other and file size. What can be wrong with it?
Any help would be appreciated.
Thanks in advance.
