Activity › Forums › Apple Final Cut Pro Legacy › Importing ALE files
Importing ALE files
Posted by John Dehn on November 5, 2005 at 3:36 pmDoes anyone know how I could import an Avid log file (ALE)? It’s not an edit list, but just the logging info that I want to get into the FCP browser. (FCP 5 or 4.5)
-JohnSteven Gonzales replied 20 years, 10 months ago 4 Members · 6 Replies -
Steven Gonzales
November 5, 2005 at 3:57 pmYou can bring the ALE into Cinema Tools, and then export it back out of Cinema Tools as a Final Cut Pro batch list.
Alessandro Capitani
November 5, 2005 at 4:30 pm[John Dehn] “Does anyone know how I could import an Avid log file (ALE)? It’s not an edit list, but just the logging info that I want to get into the FCP browser. (FCP 5 or 4.5)”
Give a try to Sebskytools.
https://www.dharmafilm.com/sebskytools/
I have used it for years to convert Avid’s medialog files to FCP.
Biiiig kudos to Peter Reventlow, Sebsky Tools developer.
Alessandro Capitani
Alessandro Capitani
November 5, 2005 at 6:54 pm[Shane Ross] “Cinema Tools does it…and it’s free if you have FCP…”
Sebsky is a free and standalone small app. It does also other conversions in a drag and drop fashion, very simple to use. In my opinion it definitely deserves a try.
Ale.
John Dehn
November 7, 2005 at 12:31 amThanks. My partner tried it and says it converted the ALE to a txt file, but I’m not sure how to import that into FCP.
-John
Steven Gonzales
November 7, 2005 at 3:06 amSelect the Browser window, create a new bin (folder) and open it, then under the File menu select Import, then Batch List at 29.97 fps (the fps will be set at whatever your default sequence present timebase is set to). Then point to the file, and it will import.
If you haven’t selected a browser window as the active window, import batch list will be grayed out.
