Activity Forums Adobe After Effects importing .ai – ‘saved without pdf content’ problem
  • importing .ai – ‘saved without pdf content’ problem
    Posted by Jeaster on December 18, 2006 at 5:20 pm
    I’m importing a 720×576 300ppi Adobe Illustrator image into After Effects that was saved with the PDF compatibility setting.
    When I drag it onto my composition I only see the message,
    ‘This is an Adobe Illustrator file that was saved without PDF content. To place or open this file in other applications, it should be re-saved from Adobe Illustrator with the “Create PDF Compatible File” option turned on. This option is in the Illustrator Native Format options dialog box, which appears when saving an Adobe Illustrator file using the Save As command.’
    Anyone else had this problem?
    Or, should I post this in the Adobe Illustrator forum?
    Jeaster replied 19 years, 8 months ago 12,476 Members · 2 Replies
  • Jeaster
    December 18, 2006 at 6:22 pm
    Now when I import layers only the handles can be seen. Please help.
    James
  • Jeaster
    December 18, 2006 at 6:24 pm
    Also, images that were built as 720×576 in Illustrator are 573×504 in After Effects. Why?
