Activity Forums Adobe After Effects importing AI CS2 into AE
  • importing AI CS2 into AE
    Posted by Lriv on October 13, 2005 at 5:47 pm
    I’m trying to import illustrator CS2 outlined text files into after effects, but the text gets cropped based on the document size instead of my bounding box. I’ve tried the following solutions without success:
    – Saved in legacy format, but it still gets cropped
    – Turned off “use compression” in CS2, but it gets cropped
    – increased the document size (700×5300 pt – due to the project) but I get an invalid error that doesn’t go away even after I click OK
    – saved as eps format, which works fine except if I need to have multiple layers
    Any advice is appreciated…thanks in advance
    Lriv replied 20 years, 10 months ago 2 Members · 2 Replies
  • Frank Ruggiero
    October 13, 2005 at 7:24 pm
    Sometimes I will draw a box around the text in Illustrator, and then go to Object > Crop Area > Make. And then resave it. that might help.
  • Lriv
    October 17, 2005 at 4:21 pm
    thanks for the help, but that didn’t work either. the image still gets cropped based on the document size
