Activity Forums Apple Final Cut Pro Legacy Importing After Effects
  • Importing After Effects
    Posted by Jimmy Stewart on February 2, 2010 at 8:54 pm
    hi,
    i have a 720 x 480 comp (dv ntsc) in AE. when i import it into my final cut pro project (same specs as AE), the text looks rough. the animation quicktime (out of AE) however looks great. so its something with the import.
    thoughts?
    thanks,
    jimmy
    Rafael Amador replied 16 years, 7 months ago 3 Members · 5 Replies
  • Stephen Smith
    February 2, 2010 at 9:06 pm
    Be sure to set your “Render Settings” Quality to Best and Resolution to Full in your Render Queue. That can kill the quality of text. Hope this helps and keep in mind DV is not a fan of text.
    Utah Video Productions
    Check out my Motion Tutorials
  • Jimmy Stewart
    February 2, 2010 at 9:19 pm
    thanks, stephan. i do have the AE renders set to “full” and “best” but it still looks ragedy when importing to FCP. i even started a new higher res project and it still looks like hell. however the quicktime itself looks great out of AE
    stumped
  • Stephen Smith
    February 2, 2010 at 9:26 pm
    I believe this might be a symptom of the DV codec. Try exporting it out in an Animation or Prores type codec.
  • Jimmy Stewart
    February 2, 2010 at 10:11 pm
    i tried animation but will try prores next
  • Rafael Amador
    February 3, 2010 at 10:57 am
    [Jimmy Stewart] “. when i import it into my final cut pro project (same specs as AE), the text looks rough. the animation quicktime (out of AE) “
    Best setting and Prores.
    Rafael
    http://www.nagavideo.com
