Activity Forums Adobe Premiere Pro Importing after effects compositions.
  • Importing after effects compositions.
    Posted by Christopher Mallan on June 22, 2009 at 10:29 am
    I have a title sequence made in Adobe After Effects that I want to add to a video project made in Premiere. However, when I import the composition, it appears distorted, at a different size or the audio doesn’t play. Anything I need to be aware when importing?
    Eric Jurgenson replied 17 years, 3 months ago 2 Members · 1 Reply
  • Eric Jurgenson
    June 22, 2009 at 12:31 pm
    Typical workflow with AE to Premiere would be to render the AE project (make movie), and import the resulting file into Premiere.
    That being said, you should be able to import an AE project into Premiere. I would double check your composition settings – make sure they match your Premiere settings.
