Activity Forums Adobe After Effects Importing AE, PS, and AI files
  • Importing AE, PS, and AI files
    Posted by Jerry Smith on June 23, 2016 at 10:55 pm
    OK, this will be the first of a few questions that you can file under: “everything you wanted to know but were afraid to ask about AE”.
    If I import an AI or a PS file into AE and then change the AI or PS file those changes show up in AE. Something like this definitely happens. I’ve seen it! 🙂
    On the other hand, if I import AE project 1 into AE project 2, close AE, then open AE project 1 and make a change, and then close it and open AE project 2, nothing will have changed in AE project 2.
    Have I got that right?
    Thanks in advance
    Walter Soyka replied 10 years, 2 months ago 3 Members · 2 Replies
  • Greg Gesch
    June 23, 2016 at 11:08 pm
    Hi. Yes, you’ve got it right. Any changes made are only saved in the file they are made in.
  • Walter Soyka
    June 24, 2016 at 12:16 pm
    [Jerry Smith] “If I import an AI or a PS file into AE and then change the AI or PS file those changes show up in AE. Something like this definitely happens. I’ve seen it! :)”
    Importing footage creates a pointer in the After Effects project to the media. As you note, changes to the media will be reflected in Ae.
    [Jerry Smith] “On the other hand, if I import AE project 1 into AE project 2, close AE, then open AE project 1 and make a change, and then close it and open AE project 2, nothing will have changed in AE project 2.”
    Importing a project is different; Ae does not point back to the original AEP. Rather, it copies the contents as they were at the time of import into the new AEP.
    There’s a product over at Aescripts that lets you sync projects, more like the way you describe:
    https://aescripts.com/project-sync/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
