Activity Forums Adobe After Effects Importing AE masks into Combustion (and vice versa)
  • Importing AE masks into Combustion (and vice versa)
    Posted by Peter O’connell on September 9, 2005 at 2:40 am
    Hi, does anyone know if it is possible to import AE masks into Combustion. Or to convert a AE mask animation preset into a gmask file? Or vice versa.
    Pete
    Peter O’connell replied 21 years ago 2 Members · 2 Replies
  • Mylenium
    September 9, 2005 at 7:52 am
    I doubt it since they are completely different both in code and implementation (there is simply no equivalent to G-masks in AE). If copy& paste from one prog to the other doesn’t work, I guess you are out of luck. The only thing I can think of is to copy masks from AE into Illustrator and then import that Illustrator file into combustion*. It’s a complete one way road, though.
    Mylenium
    [Pour Myl
  • Peter O’connell
    September 9, 2005 at 8:07 pm
    Hi Mylenium, thanks for the info. If I am not mistaken there is an equivalent in after effects more or less to combustions gmask file format. You can save a mask as an effects preset, keyframes and all in AE. It is saved as an ffx file. So basically I was looking for and ffx to gmask converter. Oh well
    Pete
