Activity Forums Avid Media Composer Importing AE GFX
  • Importing AE GFX
    Posted by Richard Smith on August 11, 2008 at 5:59 pm
    I’m having simple problem that’s slowly become a major problem of importing
    a simple animated arrow that follows an edge of device so that it can be highlighted. The arrow is slightly rotated 11 degress so as to be slightly pointing down.
    Every time I import it in to Avid Media composer and it dosen’t matter what setings are, such interlaced, non- interlaced, upper field first, lower field first, etc, etc. the edges look like there swimming. I can’t get a clean edge. Out of AE I Export using the Animation Codec
    with Alfa and straight unmatted. So what do i have to do stop it from anti-alising onlong the edges?
    John Cuevas replied 18 years ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Hancock
    August 11, 2008 at 6:02 pm
    Is it aliasing on an external monitor, or your computer monitor?
    Also, what type of project are you in and what are your settings in After Effects?
    Michael.
  • Richard Smith
    August 12, 2008 at 1:22 pm
    it’s anti alising on both the monitor and and on the computer screen
    the gfx moves very slow down the screen. the setting are for highrez
    and it looks their. just when I import it into Avid.
  • Brian Lehmbeck
    August 12, 2008 at 1:44 pm
    Richard,
    Is this a solid arrow? or an outline of an arrow? And what color is the arrow?
    There a number of factors that could cause that to happen that infomation will help figure it out.
    System Specs:
    Avid Xpress Pro v5.7.5
    Window XP SP2
    HP Workstation xw4100 Pentium 4 2.60 GHz 2 gig RAM
    After Effects v7.0
  • Richard Smith
    August 12, 2008 at 2:01 pm
    The arrow is solid white. with no stroke, shadow. Just a simple arrow. The project is SD 720×480
  • Brian Lehmbeck
    August 12, 2008 at 4:27 pm
    OK… Well if it helps here is the worflow from AE to Avid that I use with success:
    From AE:
    When I have moving elements such as text or graphics I turn the Motion Blur on for each of my moving tracks
    In render settings make sure Motion Blur is set for selected tracks
    In the Output module settings I use Quiktime, Animation, millions of Colors+, RGB+Alpha, Millions of Colors+, Straight
    On the Avid Import I use:
    Aspect=601/709, non-square
    Color Levels=601/709
    Field order=Even
    Alpha=Invert Existing
    Hope that helps….
    System Specs:
    Window XP SP2
    After Effects v7.0
  • Richard Smith
    August 12, 2008 at 5:16 pm
    motion blur wouldn’t be nessessary the for the speed at which this arrow moves. as for export setting, the same here as you use
  • John Cuevas
    August 13, 2008 at 7:54 pm
    Avid’s use D1-which is 720-486. Not 480, the Avid will stretch and move your AE composition to fit and those 6 pixels will mess everything up.
    Go back to AE and resize your composition to 720×486, export DV settings, animation(I prefer the AvidCodec for the increased speed on importation). If color is critical you may have to throw a levels effect on an adjustment layer tweaking black and white outputs.
    Switching the size to 486 should fix the problem though.
    Johnny Cuevas, Editor
    http://www.ckandco.net
