Importing ae compostion in Premiere pro (problem)
Hey guys!
I’m working on a project in premiere pro where I added colorista. I then tried replacing with after effects compostion but the colorista reset itself. So I tried finding a new way and I thought: what if I just make an adjustment layer and import the comp in premiere pro and leave the video with colorista on the bottom layer. I added a blur and a stroke on that adjustment layer in ae. But HERE IS THE PROBLEM, when I imported the comp in premiere pro, there was no blur, but the stroke was there.
What is the problem? What to do? I just need the same color correction in after effects as premiere without exporting the video from premiere and importing in after effects.
I am using cc2014
THANKS FOR EVERYTHING
