Activity › Forums › Apple Final Cut Pro Legacy › importing Adobe premiere into FCP
  • importing Adobe premiere into FCP
    Posted by Lawrence Eaton on January 15, 2010 at 5:31 pm
    Guess this must be a long standing issue but at this moment, I need a yea or a nay.
    Can you import a .prproj into FCP?
    If not, can someone suggest a ‘bit’ of software to enable this, please?
    Many thanks, off to feed the deer
    Lawrence Eaton
    Rafael Amador replied 16 years, 8 months ago 4 Members · 4 Replies
  • John Fishback
    January 15, 2010 at 9:46 pm
    I think at one time Automatic Duck might have done this. Not sure about the current version. Can Premiere export an XML that FCP can open? Just a thought or two.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Lawrence Eaton
    January 15, 2010 at 10:49 pm
    Thanks John. I guess this is going to be one of the traditional technological slogs. Nothing like a challenge though…
    Lawrence Eaton
  • Zane Barker
    January 16, 2010 at 4:16 am
    [John Fishback] “Can Premiere export an XML that FCP can open?”
    That would be the best option if Premiere can do it, I dont know if it can.
    The BIGGER problem that you will run into is that most likely your media files from Premiere will be incompatible with FCP.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Rafael Amador
    January 16, 2010 at 6:03 am
    The other way (FC to PP) no problems, but PP to FC doesn’t work yet:
    https://forums.creativecow.net/readpost/8/1069410
    Hopefully soon.
    Rafael
    http://www.nagavideo.com
