Activity Forums Apple Final Cut Pro Legacy Importing AAF via automatic duck – missing audio
  • Importing AAF via automatic duck – missing audio
    Posted by Phil Knox on January 21, 2010 at 3:43 pm
    We are reconstructing an edit from a few years ago (when we were using Premiere Pro) into FCP.
    The Premiere Pro project has been updated to CS4. It has offline files, all with correct timecode references
    The project was exported via the PremPro AAF format.
    Via automatic duck, this AAF file was imported into final cut pro.
    So far, so good – the files come in with the correct t/c references. All video tracks present and correct.
    However, it loses the sync audio. On the audio tracks, it has correctly imported any non-sync (ie soundtrack or wildtrack) audio files but any sync audio such as an interview clip has the picture track correct but no associated sound file.
    We have batch captured a couple of clips and this works fine for the pictures – correct timecodes and edits. The audio is captured but not laid down onto the timeline – which will greatly extend the time to complete the re-edit if we need to re-sync all the audio!
    Any advice appreciated, although I do fear the shakey heads (Hmmm, Premiere to FCP – what were you thinking?!)
    thanks in advance
    phil
    Phil Knox replied 16 years, 6 months ago 2 Members · 3 Replies
  • Walter Biscardi
    January 22, 2010 at 4:36 am
    When we do AAF’s from Avid we get all the original tapes and re-capture all the media fresh on our FCP systems. We don’t bring in the capture files.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Phil Knox
    February 2, 2010 at 11:57 am
    Hi Walter –
    that’s exactly what we’re doing, we’re using the project timecodes to recapture in the footage in FCP. No native capture files are being reused.
    The footage captures in with the correct in and out points, the actual capture file has captured with audio, but the timeline in FCP is completely devoid of any sync audio. There are not even any placeholders for where the audio files should be.
    Whilst I can then use the video in and out points to go back to the captured clip, set these in and out point and then put the audio sync onto the timeline, this will be a tedious process!
    Any thoughts?
    Many thanks
    phil
  • Phil Knox
    March 5, 2010 at 11:35 am
    I guess this is a blank then.
    Time to get the intern to resync the audio in the 15min film…
    Will keep trying and if I work it out will pop a post back here.
