Activity Forums DaVinci Resolve importing a still frame but using for duration of more than 1 frame.
  • importing a still frame but using for duration of more than 1 frame.
    Posted by Nat Jencks on January 5, 2014 at 9:27 pm
    Is there a way to do this? Title card that should last 4 second, and which I have a single frame for?
    Nice that v10 lets me cut stills into the timeline, but I need to set their duration as more than 1 frame. Possible?
    -Nat
    Michael Cinquin replied 12 years, 7 months ago 5 Members · 5 Replies
  • Clark Bierbaum
    January 5, 2014 at 10:21 pm
    I’ve done cmd c cmd v in past versions, not great but better than nothing!
    Clark Bierbaum
    Color Grading / Post Consultant
    GarnetColor.com
    Charlotte, NC
  • Eric Rosen
    January 5, 2014 at 10:36 pm
    Think you can you can drag out the length you need on the edit page.
    Eric Rosen
    http://www.colormatters.tv
    p. 206.552.9806
  • Nat Jencks
    January 6, 2014 at 12:27 am
    Wow. I was not expecting that simple of a solution. Thanks a lot!
    best-
    -Nat
  • Nick Anderson
    January 6, 2014 at 5:02 pm
    Haven’t upgrade to v10 yet. But I’ve done this all the time in v9.
    Set speed to 0%, then drag to whatever length you want.
  • Michael Cinquin
    January 9, 2014 at 12:27 am
    a solution : script it. In the terminal (OS X) : type this
    x= [then drag the still image from the Finder, then Press return,
    after that you can copy/paste the rest]
    dir=`dirname "$x"`; filename=$(basename "$x") ; extension="${filename##*.}"
    y=1000 ; while [[ "$y" -lt "2000" ]]; do
    ln "$x" "$dir/$y.$extension" ; let y+=1
    done
    and you should have in a matter of seconds a loop of 1000 images that don’t use more space on the disk than the original image (did not test the script but should work, I use these sort of scripts all the time).
    Michael Cinquin
    Charbon Studio, film finishing and DCP mastering
    Post-production tools
