Activity Forums Apple Final Cut Pro Legacy Importing a sequence of stills
  • Importing a sequence of stills
    Posted by Russ930 on December 22, 2006 at 11:57 pm
    I am looking for an easy way to import a series of stills at the same time onto the timeline (animation) and to control their duration (which is the same for each still)
    Any help would be Appreciated
    Russ930 replied 19 years, 9 months ago 3 Members · 3 Replies
  • Eric Peterson
    December 23, 2006 at 12:22 am
    In FCP go to User Preferences and the Editing tab. Set your duration in the Still/Freeze Duration section. Grab your stills from the browser and pull them into the timeline.
  • Thaxter Clavemarlton
    December 23, 2006 at 12:28 am
    Name/number the images sequencially.
    Final Cut Pro (menu) > User Preferences > Editing >
    Still/Freeze Duration (set for the duration you want each “frame” of the animation to be seen)
    Then import your frames.
  • Russ930
    December 23, 2006 at 5:40 am
