Activity › Forums › Adobe After Effects › importing a psd file to after effects
  • importing a psd file to after effects
    Posted by Gon Perdigao on February 21, 2008 at 3:34 pm
    Hi there, sometimes when i import a file or replace a psd file in after effects, the file have the extension psd but only have 3 frames long and even i try to trim it to comp size, it doesn’t trim.
    The only way to get around is, to open the psd file and rename it and save it in another location.
    But sometimes not even that result, can anyone now why this happens, and how can i solve this?
    Wayne Wrzesinski replied 13 years, 1 month ago 4 Members · 4 Replies
  • Darby Edelen
    February 21, 2008 at 7:16 pm
    It sounds like you are most likely importing a single item that AE is interpreting as a part of an image sequence. If your file names end in a number, then AE will assume that they are part of an image sequence and look in the same folder for other images ending in numbers. So if you have MyPic1.psd, MyPic2.psd and MyPic3.psd all in the same folder AE will create an image sequence of 3 frames when you import one of those images.
    You can uncheck the “Image Sequence” checkbox in the import dialog when importing these images to get only 1 still image.
    Read here for more information:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS3878526689cb91655866c1103906c6dea-7f78.html
    There is also a preference that controls the default duration of imported still footage items:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS3878526689cb91655866c1103906c6dea-7e9c.html
    But that should still allow you to trim or extend the layer in time.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Gon Perdigao
    February 22, 2008 at 1:56 am
    thanks a lot 🙂 it work just fine
  • Ekaete Bassey-fujah
    June 10, 2012 at 3:42 pm
    Thank you for this post. Even the manual did not help!
  • Wayne Wrzesinski
    August 25, 2013 at 3:13 pm
    That’s exactly what mine was doing.Thanks.
