Activity › Forums › Boris FX Particle Illusion › Importing a PNG sequence without Black Halo?
  • Importing a PNG sequence without Black Halo?
    Posted by Matthew Stewart on January 26, 2011 at 5:00 pm
    I’m importing a PNG sequence rendered from Maya. The sequence has transparency that is perfect when viewed in Photoshop.
    The problem is when I import them into PI3 the images are given a very small black halo.
    Is there a setting or a step I’m missing here?
    I can E-mail screen caps if it would help to clarify.
    Matt S.
    Alan Lorence replied 15 years, 8 months ago 2 Members · 1 Reply
  • Alan Lorence
    January 31, 2011 at 11:39 pm
    Photoshop might be unpremultiplying the alpha channel to display it — pIllusion doesn’t do that. Does Maya have an option to output a “straight” (or unpremultiplied) alpha channel?
    If not, you might be able to use Photoshop to “fix” the image by unpremultiplying the alpha channel, then saving (to a different filename to be safe). I don’t use Photoshop enough to know though.
    Alan.
    http://www.wondertouch.com
