Activity › Forums › Adobe After Effects › Importing a PNG sequence error
Posted by Matthew Rogers on June 30, 2010 at 8:22 pmLooked around the web and the cow and didn’t see anything related to this. I can’t import a single PNG file or a PNG sequence into After Effects.
I get the following error message.
Any thoughts?
Thanks.
-Matt
Matthew Rogers
Engine Room Edit
Boston, Ma
five13.net
http://www.engineroomedit.comMatthew Rogers replied 16 years, 2 months ago 2 Members · 4 Replies -
Michael Szalapski
June 30, 2010 at 9:31 pmFrom Mylenium’s After Effects Error Code Database: “Opening the file in another program like Adobe Photoshop and saving it from there in the same or another image format might allow you to use the data.”
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Matthew Rogers
June 30, 2010 at 9:39 pmThat’s what I ultimately did, but it seems that any png image won’t load. Strange.
-Matt
Matthew Rogers
Engine Room Edit
Boston, Ma
five13.net
http://www.engineroomedit.com -
Matthew Rogers
July 1, 2010 at 2:47 pmI’m running 9.0.2.42 currently. I tried importing an image into PS and exporting a PNG to see if the files were saved improperly or corrupt some how. Still doesn’t work.
I’ll have to hit up Adobe for some insight.
Thanks for your help.
-Matt
Matthew Rogers
Engine Room Edit
Boston, Ma
five13.net
Matthew Rogers
July 1, 2010 at 3:18 pmI created a screen grab using the mac screen grab Shift+command+4 and tired to import that into AE with no luck.
You last comment made sense. I didn’t even think that it may be an OS issue. I tried importing a PNG file and a PNG sequence on another machine and it imported without any errors.
So, it must be an OS issue. Which is also strange. We just did a complete erase and reinstall of the OS on this system about a month ago.
Which was Leopard, if that makes any difference.hmmm
Thanks again for your help on this.
-Matt
Matthew Rogers
Engine Room Edit
Boston, Ma
five13.net
