Activity Forums Adobe After Effects Importing a mask from a different computer
  • Importing a mask from a different computer
    Posted by Steve George on March 4, 2014 at 6:33 pm
    Hi Guys,
    I have after effects CS6 (with element 3d) on my macbook pro. I don’t want to use the software on my PC because it is very old and slow. I have Photoshop & AI on my pc that i don’t really want it on my mac too.
    I need to be able to import masks from PS or AI into after effects to use in element 3d. How can i do this ?
    Basically i want to trace a 3D logo outline to make it 3d in element 3d.
    I tried the auto trace in after effects but the quality is not great, id much rather import a hq mark layer if possible ?
    Any help or advice much appreciated as usual
    Walter Soyka replied 12 years, 6 months ago 3 Members · 4 Replies
  • Mike Sevigny
    March 4, 2014 at 10:50 pm
    hey Steve,
    I don’t use Element 3D much but you should be able to import/export luma mattes in and out of PS/AI/AE and most software. Just make the object to be traced black and the BG white, then use that as your ‘trace’ in After Effects.
    Mike Sevigny
    TorusFX Inc.
    https://vimeo.com/channels/mikesevigny/
    https://www.linkedin.com/pub/mike-sevigny/49/875/495
  • Steve George
    March 4, 2014 at 10:55 pm
    I don’t get too good a quality when i trace in after effects. It’s ok but not as sharp as it would be if i copied the outline in ai and pasted into a layer in ae.
    Any other solutions for this please ?
  • Mike Sevigny
    March 4, 2014 at 11:28 pm
    then you’ll want to retain the paths in a PSD and import with editable layers in AE, but as Dave said this will depend on your version.
    Although, if you mess with the Auto-Trace settings you should be able to get some pretty good results on a black and white (no grey) image.
    Mike Sevigny
    TorusFX Inc.
  • Walter Soyka
    March 5, 2014 at 11:07 am
    [Steve George] “I have after effects CS6 (with element 3d) on my macbook pro. I don’t want to use the software on my PC because it is very old and slow. I have Photoshop & AI on my pc that i don’t really want it on my mac too. “
    I would suggest you reconsider this. Photoshop and Illustrator are valuable companion applications for After Effects.
    [Steve George] “I need to be able to import masks from PS or AI into after effects to use in element 3d.”
    With both Ae and Il on the same computer, you can simply copy and paste a path from Il as a mask.
    Without Il, but with Ae CS6 or CC, you can import an .AI file into Ae, then drag it into your comp. Right-click on the name of the layer in the timeline panel, then choose Create Shapes from Vector Layer [link]. You can copy and paste a path from a shape layer into the path of a mask if you need to.
    Walter Soyka
