Activity Forums Apple Final Cut Pro Legacy Importing a file into Compressor from FCP7
  • Importing a file into Compressor from FCP7
    Posted by Tom Fino on August 4, 2017 at 10:57 pm
    Trying to use the “Publish to YouTube” template in Compressor to compress a FCP7 file.
    However, when I start in Compressor and use Job>Source>File to import the file, the FCP files in my hard drive aren’t highlighted and can’t be imported/selected.
    If I start in FCP, send the project to Compressor, and then choose the “Publish to YouTube” template, it starts a new batch tab – not the tab that includes my FCP project.
    Any advice would be appreciated. Thanks.
    Shane Ross replied 9 years, 1 month ago 2 Members · 1 Reply
  • Shane Ross
    August 5, 2017 at 2:09 am
    Which version of Compressor? The only one you can SEND TO from FCP 7 is 3.5. Any later version and there is no such link. And what do you mean by FCP files?
    Best option is to export from FCP 7 as EXPORT>QUICKTIME MOVIE. Don’t recompress…and not QUICKTIME CONVERSION. Just QT movie. This will export a movie with the same settings as your sequence. That will be your master. Bring that into Compressor then to compress for YouTube
    Shane
    Little Frog Post
