Activity Forums VEGAS Pro Importing a DVD into Vegas??
  • Importing a DVD into Vegas??
    Posted by Ray Sherman on September 19, 2008 at 9:18 pm
    I am currently trying to import a dvd that I have made in the past into Vegas Pro 8 in which I’m having one problem. The following is how I am importing the dvd;
    File
    Import
    DVD Camcorder Disc
    The disc that I am using “is not” from a camcorder it’s a normal dvd-r disc that I have burned in the past.
    The movie is importing fine and looks good. The problem I’m having is that the audio “does not” match with the video. I believe that the movie is Dolby 5.1 surround in which I’m placing it into a stereo formatted project. Is there anything that you can suggest in rectifying my problem? As always, your help would be most appreciated. Thank you, Ray
    Danny Hays replied 17 years, 12 months ago 2 Members · 2 Replies
  • Ray Sherman
    September 19, 2008 at 9:59 pm
    I would like to add to my post that some of the audio is missing as well. Thanks, Ray
  • Danny Hays
    September 21, 2008 at 6:59 pm
    Try this. Import media, drop the type down and select any, all files. then point to the DVD and import the VOB files, and then save the project to your hard drive as Vegas will try to play the files from the DVD otherwise. As far as the 5.1 dolby audio, I am not sure if Vegas will decode an AC3 file into six seperate tracks. May need a AC3 decoder. Danny Hays
