Importing a DVD into Vegas
Posted by Rick Hughes on July 2, 2012 at 12:57 pmAfter a recent dive trip I have been given 2 DVD’s and I wish to incorporate them in with my DVD footage into a single DVD.
Source & edit will all be for PAL format.What is the correct way to ‘drop ‘ the DVD into a Vegas Project ?
Looking at file structure there are:
There are 2 folders Audio_TS and Video_TS, in the latter there are a number of files ..2 x BUP files
2 x DVD IFO files
3 x DVD VOB files (video_TS, video_TS1, Video_TS2)How do I drop these into the project …. or is there a neater ‘import’ DVD option ?
I’ happy to drop in all and then edit down to what I want.
Mike Kujbida replied 12 years, 4 months ago 5 Members · 12 Replies -
Mike Kujbida
July 2, 2012 at 1:15 pmHere’s a better way to do it that works like a charm 🙂
Vegas allows you to open up a DVD .IFO file. This imports the entire .VOB chain for both video and audio tracks.
Click File / Open, then navigate to your VIDEO_TS sub directory and enter *.IFO in the File name input field.
For a regular DVD you will see a VIDEO_TS.IFO, and a VTS_01_0.IFO. Select the VTS_01_0.IFO file and click on Open.
Don’t try this on a DVD disk because Vegas will try to build an .sfk file containing audio peaks in the VIDEO_TS directory. -
Rick Hughes
July 2, 2012 at 4:12 pmI’m slightly lost on the response … you say open the DVD and browse to the Vide0_TS directory
Just to be clear this is a ‘normal’ DVD disk someone had ‘burnt’
I do see video_TS.IFO and VTS_01_0.IFO
I’m following as far as there … but then you say:
Don’t try this on a DVD disk because Vegas will try to build an .sfk file …The video is on a regular DVD disk so I don’t follow what you mean.
Mike Kujbida
July 2, 2012 at 5:01 pmThe easiest thing to do is to copy the entire VIDEO_TS folder to your computer and then follow the steps I outlined.
An sfk file is the audio waveform file that Vegas uses.
It’s not necessary unless you want to see the audio on your timeline. -
Gilles Gagnon
October 7, 2012 at 3:26 amThanks Mike!
This post helped me out. Worked like a charm.Gilles
Mike Kujbida
October 7, 2012 at 2:32 pmMy pleasure Gilles. I’ve used this technique a few times since I found out about it (thanks to Gary James for sharing it) and it works great!!!
Jacob Newburn
October 1, 2013 at 9:00 pmI have extracted the VOB file from a DVD, but when i drag the .IFO into vegas it says:
“none of the file dropped on vegas pro could be opened”Details of file:
General
Complete name : G:\TGTB&TU\TGTBTU D124\VIDEO_TS\VTS_01_0.IFO
Format : DVD Video
Format profile : Program
File size : 122 KiB
Duration : 400ms
Overall bit rate mode : Variable
Overall bit rate : 2 499 KbpsVideo
Format : MPEG Video
Format version : Version 2
Duration : 400ms
Bit rate mode : Variable
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Compression mode : LossyAudio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 400ms
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Language : EnglishAudio #2
Format : AC-3
Duration : 400ms
Language : GermanAudio #3
Format : AC-3
Duration : 400ms
Language : FrenchAudio #4
Format : AC-3
Duration : 400ms
Channel(s) : 2 channels
Language : English
Language, more info : Director’s commentsText #1
Format : RLE
Format/Info : Run-length encoding
Bit depth : 2 bits
Language : EnglishText #2
Format : RLE
Bit depth : 2 bits
Language : GermanText #3
Format : RLE
Bit depth : 2 bits
Language : French
Language, more info : NormalText #4
Format : RLE
Bit depth : 2 bits
Language : Dutch
Language, more info : NormalText #5
Format : RLE
Bit depth : 2 bits
Language : Swedish
Language, more info : NormalText #6
Format : RLE
Bit depth : 2 bits
Language : Finnish
Language, more info : NormalText #7
Format : RLE
Bit depth : 2 bits
Language : Norwegian
Language, more info : NormalText #8
Format : RLE
Bit depth : 2 bits
Language : Danish
Language, more info : NormalText #9
Format : RLE
Bit depth : 2 bits
Language : Portuguese
Language, more info : NormalText #10
Format : RLE
Bit depth : 2 bits
Language : Polish
Language, more info : NormalText #11
Format : RLE
Bit depth : 2 bits
Language : Greek
Language, more info : NormalText #12
Format : RLE
Bit depth : 2 bits
Language : Hebrew
Language, more info : NormalText #13
Format : RLE
Bit depth : 2 bits
Language : Turkish
Language, more info : NormalText #14
Format : RLE
Bit depth : 2 bits
Language : Czech
Language, more info : NormalText #15
Format : RLE
Bit depth : 2 bits
Language : Slovenian
Language, more info : NormalText #16
Format : RLE
Bit depth : 2 bits
Language : Croatian
Language, more info : NormalText #17
Format : RLE
Bit depth : 2 bits
Language : Romanian
Language, more info : NormalText #18
Format : RLE
Bit depth : 2 bits
Language : EnglishText #19
Format : RLE
Bit depth : 2 bits
Language : GermanText #20
Format : RLE
Bit depth : 2 bits
Language : FrenchText #21
Format : RLE
Bit depth : 2 bits
Language : DutchMenu #1
Duration : 400ms
00:00:00.000 : Chapter 1
List (Audio) : 0 / 1 / 2 / 3
List (Subtitles 4/3) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0
List (Subtitles Wide) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 / 11 / 12 / 13 / 14 / 15 / 16 / 17 / 18 / 19 / 20
List (Subtitles Letterbox) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 / 11 / 12 / 13 / 14 / 15 / 16 / 17 / 18 / 19 / 20
List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0Menu #2
Duration : 400ms
List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 -
Mike Kujbida
October 1, 2013 at 9:36 pmJacob, make sure you drag the one labeled VTS_01_0.IFO as the other one (VIDEO_TS.IFO) won’t work.
Jacob Newburn
October 2, 2013 at 10:23 amThanks.
That is the name of the file i was trying to open.
Maybe the problem is with the rip.
I have the original dvd9, can anyone talk me through ripping it properly?
Thanks again, J
Mike Kujbida
October 2, 2013 at 2:14 pmI’ve only done this with a DVD5, not a 9.
If it’s a copyrighted video (i.e. commercial product) you’re trying to rip, that would explain it as Vegas won’t allow you to import it. -
Ken Bennett
May 18, 2014 at 11:12 pmThis does not work. i get a format error every time.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!
