Activity Forums Zaxwerks Importing 3D things with Invigorator Pro v3
  • Importing 3D things with Invigorator Pro v3
    Posted by Gary Rice on March 8, 2014 at 4:39 pm
    I’m beginning to experiment with Cinema 4D and Bryce – Bryce first.
    I need to model a landscape with trees. Bryce seems like the right choice.
    I’ve successfully created a basic terrain in Bryce and imported it to AE via Invigorator Pro v3. But only the terrain came through. The tree on the terrain did not.
    Is this a limitation of Bryce/Invigorator or did I just do something wrong that I can correct?
    Gary
    Edward Wu replied 12 years, 6 months ago 2 Members · 1 Reply
  • Edward Wu
    March 10, 2014 at 8:40 pm
    Hi Gary,
    I’m not sure what model type you are working with, but if possible, try exporting your objects out using the Maya (.obj) format or Lightwave (.lwo). These two formats usually work the best with our program. You should be able to import your models without any problems using these two formats. If you are still having problems, please let me know.
    Best,
    Edward
