Importing 3D objects into AE – some points missing?
When I import some 3D objects into AE 5.5, some parts of the object are not visible at certain angles. It doesn’t happen with every 3D object. I’m looking to get a wireframe look – see the screenshot attached.
My process:
Build an object in 3D software, or import one from elsewhere.
Save as .3ds
Import .3ds into Photoshop
Save as .psd
Import .psd into AE as Live3D object
Rotate the layer controller in 3D.I’ve tried adjusting the 3D Render Settings in Photoshop to remove/not remove backfaces & hidden lines, but can’t seem to find a setting that works.
Screenshot shows Photoshop version on the left, and AE version on the right, with missing vertices.
Thanks in anticipation 🙂
Tom
