Activity Forums Adobe After Effects Importing 3D object into AE
  • Importing 3D object into AE
    Posted by Kim on August 5, 2005 at 2:25 am
    1) Can we import a 3D object into AE composition? If this can be done, what is the file type/extension that we can import and supported by AE?
    2) Also, is there any 3D object library online that I could go in to download or any source from internet that I can purchase to obtain the files?
    3) If we can import a 3D object into AE composition, will it affect the render duration that takes longer time? IS there any method to shorten the render duration if it is longer?
    Hope could hear from anyone who know about this. Appreciate for any advice.
    Thanks a lot!
    Chris Smith replied 21 years, 1 month ago 3 Members · 2 Replies
  • Yoondo
    August 5, 2005 at 2:41 am
    You can import 3d objects using Zaxwerks Invigorator. AE alone cannot bring
    in 3d objects, however.
    You can download some free 3d objects by going to 3d CAFE. You can then
    control the objects’ movements by using controllers in AE as shown in
    John Dickinson’s Invigorator tutorials.
    I have done some 3d animation using this method and it is the only way to go
    without using an actual 3d program. I love it.
    Hope that answers.
  • Chris Smith
    1. Yes and no. AE is not made for it so you need to use Zaxwerks invigarator which will load some objects. It’s usually a better workflow to use 3D objects in a 3D application, render out passes and comp them in AE. If you need matching camera then import the cam data from the 3D app.
    2. https://www.turbosquid.com
    https://www.3Dcafe.com
    3. Well, yeah. But, Zaxwerks is not too bad. Usually the render time hits in 3D land is from raytracing, Refractive index transparency, displacements, etc. None of which Zaxwerks does as far as I know.
    Also look in the Cow archives. This question is asked everyfew weeks it seems.
    Chris Smith
    https://www.sugarfilmproduction.com
